Hey everyone... been a while since I visited the forum or did any work to my Vx (other than regular maintenance) but got an issue that became a major problem not too long ago, resolved the issue today and wanted to share my experience as I didn't find anything overwhelmingly decisive in this area on the forum (although there is a thread or two that come close).
Symptoms:
Intermittent high idle topping out at 3,000 RPM when in "Park" or "Neutral" - around 1,200RPM when in gear... and bearing down on forward. The idle was consistent but high, required extra effort to stop the vehicle at lights, and keep it from moving - it lounged forward once foot is off gas pedal.
Subsequently, the vehicle began to run at extremely high temperatures. Never quite overheated but almost right on top of "H" on the gauge. Fuel economy went to *****.
Resolution:
Pulled IAC and MAF sensor, cleaned both with CRC MAF Sensor Cleaner and IAC was cleaned with CRC Throttle Body/Intake Cleaner - both readily available at your neighborhood auto store like Autozone, Advance Auto Parts, Pep Boys, NAPA, Carquest, O'Reilly, etc... Both sprays did a good job getting grime and gunk off with seemingly no effort. Also removed and cleaned EGR valve and replaced PCV off the driver's side of the engine head cover. (new PCV was like $2.98USD)
Hope this helps anyone having similar issues. My Vx is an '01 with 111,000 miles on it at this point. If anyone has any questions, post 'em here!
Good luck.
