I have an odd problem and wondered if anyone else had experienced this.
When I start the VX in the morning the AC comes on fine. When I leave work it also kicks in as usual, however if I stop somewhere then get back in the VX, the fan is dead. This started a couple of months ago and usually I can hit the AC switch, or fumble around with the Auto and inside air buttons to get it back on. Yesterday it was just plain dead (and about 95 degrees outside). I could feel that cold air was available so the compressor was still working - I think the issue is with the fan. I eventually got it up to speed with the outside air opened and the fan kicked on - my only thought was that the flow of air moved the blades just enough to get it moving. If so, this sounds like the motor is about to go. Any thoughts on that or has anyone seen a similar issue? I tried searching but didn't find anything quite like it.
-- John
