I just bought a 99 with 106K and the electric fan stopped coming on. It worked on the way home, then I tried to blow the horn, but it didn't work. The ground wire wasn't connected and I don't know if I blew a relay or fuse. I checked all the fuses under the dash and engine compartment and they all were good. Any ideas would greatly be appreciately since it's in the high 90's here and I can't run the air. Thanks
