Results 1 to 2 of 2
Thread: I need help
    Mar 2011
    1999 Black VX, #1094
    I need help
    My electric fan stopped working. If I run the air, it runs hot. I would appreciate any ideas on how to fix. I checked all fuses under dash and in engine compartment. Thanks
    01, LineX tan/black, 1055
    Quote Originally Posted by glenngw3 View Post
    Check voltage at the fan electrical harness, turn on the AC, if you get 12 volts, the fan is bad, if not, start back tracking until you find the open in the wiring....
    See page 1A-52 of the VX shop manual that can be found under the downloads section to the left. I highly recommend perusing the manual, not everything between the model years is the same, but its close enough.
    On a side note, update your profile!!!! I assume you have a VX now, welcome to the club/sickess
