I had bad control arm bushings and the symthoms were very differant. I would get a rythmic bad vibration from the bad side that would yank the steering wheel like the tire had a flat spot in it...but it would only happen during normal accelerations and usually stopped past 40-45mph. There is a tread on here somewhere about it.
Back to somewhat on topic, a somewhat common cause of clunking during acceleration/ braking is the tramsmission mount bolts loosening/ falling out. Myself included, several on here have had this happen.
The creaking during braking I think is normal in older drivetrains. When stopping, the car is still trying to go forward while in gear and idling so suspension part will creak.
Sooooo, anyway, we're not talking about that kind of all-over squeaking that the brakes do when they're just at the edge of holding you at a stop? eg, the noise doesn't go away when you really stomp on the brakes?
