I'm gonna agree to disagree with this statement. sure at rolling speed, you lose an amount of rubber contact with the road as the tires expand in the middle of the tread, but what happens when you press those brakes hard and the weight of the vehicle is thrown onto the front tires? you then have 100% contact and have regular tire grip.
Lets see if i can word this to make sense as it does in my head
As well, if we are talking safety, which is my point for inflating my tires so high; if you have your tires at lower pressure, say 29 psi as your door jam suggests, how is your vehicle supposed to handle in a panic skid or quick swerve?  My reasoning is, as your sidewall gives, it causes body roll, increasing chance of a rollover. I personally would rather skid a little (key word little), than have the tires grab hard and roll me over.
Now, this also supports my thought behind hard straight line braking, if you swerve and put the weight of the vehicle on 2 tires, you now are operating at optimal traction levels (enough to skid but also handle). Rather, at low tire pressure you increase your traction to a level of rollover or poor handling (low tire pressure proves to make for sloppy handling).
Let the bashing and arguments begin
