I took the outer gas cap closure off to repaint. I can get all the screw/bolts back in except I can't seem to get the piece that holds the lock mechanism flat to the vehicle reattached. Is there a trick to this. The screw goes in through the hole, then the metal piecewhich is sort of an L bracket, fits only one way, then the round nut goes on, but it is not possible to get nut on if L bracket is positioned, nut goes on fine without L bracket but then the locking mechanism has nothing to hold onto to keep flush.
I believe I am putting everything back the way I took it apart, I think. If anyone has a picture of gas cover open this L barcket I am referring to is opposite the hing, hing would be at 3:00, bracket at 9:00
Help
