Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Solutions to Window & Cup Holder
  1. #16
    Dec 2004
    '99 VX Astral Silver #0949
    Quote Originally Posted by samendalk View Post
    For a permanent solution, the problem appears to be that the metal bracket that goes up and down the tracks and attaches to the window is only gripping the tracks on the left side but not on the right.
    On the right side it follows a the track but it doesnt grip it, so if it were pushed back it comes off the track easily.
    If this can be fixed by adding a piece that grippes the track like it does on the left side, this issue can be permanently fixed.
    I am working on this and if anyone can make this, plastic or metal, that would be great.
    here are some pictures showing how it comes off the track.
    right side of track
    left side of track
    DO NOT make the arm grip the track!!
    if you try, you WILL break the Tabs on the glass!
    THIS tension is what breaks them!
    DO shim the track closer to the glass so the glass rests on the track "Arm" with NO tension!
    The metal bracket, with the window bolts; is what I have been referring to as the regulator "Arm"
    Sometimes I Wonder......
    Why Is That Frizbee Getting Bigger?
    Then It Hits Me
  2. #17
    Feb 2010
    2001,Kaiser,1130
    Yeah.. this whole system is pretty f-d up. Would it have hurt Isuzu to have a normal scissor mechanism What is the mechanism on the trooper?
  3. #18
    Great tip Bulldoggie
    thats certainly a different way to look at it.
    I think you're right, so i'll give it a shot hopefully tomorrow, i'll come back with the results.
  4. #19
    Dec 2004
    The window tilting down by the mirror while raising, is a whole 'nother Ball game.
    For that issue, I suggest the many other posted fixes.
    For that issue is caused by too much friction in the front glass guide!
    a) too much friction from the front weatherstrip
    ~also a big factor in regulator speed!
    b) Glass adjusted too far forward
    c) Regulator track not aligned vertically with the angle of the rear window guide.
    d) All the above and including the track arm shimming! Although b and c are almost the same...
  5. #20
    Dec 2004
    The metal window tabs fixes the broken window tabs and keeps the windows working.
    But, in my opinion
    the TENTION that broke them in the first place is still there!
    Just my 2 cents!
  6. #21
    Quote Originally Posted by Bulldoggie View Post
    But, in my opinion
    Just my 2 cents!
    Wouldn't metal tabs be better able to handle the tension?
  7. #22
    Quote Originally Posted by rsteinmetz70112 View Post
    yup, that's the theory for the metal SBC brackets, but Bulldoggie is correct, the tension/friction on the leading edge of the glass can still be present, so (in my case) I have to still keep the front vertical rubber track well lubricated with pure silicone spray a few times per year. My windows have never jumped the track, tilted or raised up uneven, so that is an additional issue some need to address.
    p.s.....are you closer to finding/buying a VX yet, know you've been looking for a while?
  8. #23
    Dec 2004
    YES!
    but the tension will go somewhere else;
    like the nylon guide on the track, the one that does grab. (Wraps around the edge of the track) would be the next part to fail.
    The weatherstripping would wear uneven from the glass exerting pressure on one side as it goes up and down. would be a concern.
    The window tilting in the front has many documented cases of weathersrtipping wearing though by the mirror.
    But I'm not trying to scare anyone away from using them.
    I do maintenance for a living, it's my job to look for reasons why things don't work like they should.
  9. #24
    I tried adding washers to the top of the track but that forced part of the regulator onto the glass.
    still working on it.
  10. #25
    Dec 2004
    I'm guessing, that you know, that is too many!
    The most important adjustment;
    Is for the window glass to "rest" on the top of the regulator Arm's center pad (white nylon) while the glass is unbolted!!!
    (so the window is in a "relaxed" state)
    This needs to be checked with the Arm, even with the top track bolts
    and again with the Arm, even with the bottom track bolts
    and then checked again and again. (in the middle too)
    in case shimming one, effected the other!
    You might want to start at the bottom.
    Once you see the arm able to stay under the glass all the way from the bottom to top without the glass bolted you will have the right amount of shims (washers)
    Then you can bolt the glass to the Arm!
  11. #26
    Aug 2010
    01 Foxfire Red Mica VX 0441
    So am I to understand from this thread that the motor is not the real issue? I just don't want to spend $400 on a fix that won't even do anything.
    2001 VX
    Mods
    2008 HUMMER H3
  12. #27
    01, LineX tan/black, 1055
    Nope, not at all. It is a poor design/alignment issue. That plastic guide wears since the window isn't aligned, eventually it could burn out the motor if you forced it up without helping enough times. If it makes that bogged down sound, and dims your lights, thats a sign the motor is working too hard
  1. Cup Holder
    Last Post: 06/05/2015, 08:04 AM
  2. Engine problems and solutions thread
    By atilla_the_fun in forum VX Troubleshooting...
    Last Post: 01/15/2011, 01:14 PM
  3. Alternative to Gatorback - faded cladding solutions
    By Whaleboy in forum General Tips...
    Last Post: 08/02/2009, 11:49 AM
  4. Rust Solutions???
    By xdfarrx in forum Meets...
    Last Post: 04/21/2004, 08:22 PM
  5. Cup Holder
    By MZ-N10 in forum VX Talk...
    Last Post: 11/15/2003, 11:16 AM
