Quote Originally Posted by phines View Post
Not sure the compression test will show anything unless you do it after running the engine pretty hard and do the test at higher rpm's.
when i did the test i did rev the engine to see if at high rpm it would fail but still passed the test. I am going to take the rad off this weekend and have it testted by a radiator mechanic
