Results 1 to 14 of 14
Thread: radiator problem?
    1999 silver 1346
    Quote Originally Posted by phines View Post
    Zadam, you're jumping through all the same hoops that I did. I had the EXACT same problem. I replaced my radiator too and it didn't fix the problem. Did you ever check those head bolts?
    mechanic told me if the head bolt was broken it would have failed the compression leak test i did, not sure now if it is true since he said it was definatly the thermostat
    video here
    http://www.youtube.com/watch?v=X05PDw5IE1U
    1999, Ebony Black, 1856
    I have a similar issue...mine seems to start to overheat when I turn on the air...I too have replaced the fan clutch, thermostat, flushed the system, O2 pump...I'm not loosing any fluid
    1999 Astral Silver VehiCROSS #1214
    Quote Originally Posted by zadam123 View Post
    video here
    Yeah, my mechanic didn't believe it was the problem either. But after a trying everything else, we decided to replace the head gasket. That's when we found the problem.
    Not sure the compression test will show anything unless you do it after running the engine pretty hard and do the test at higher rpm's.
    -Paul
    1999 silver 1346
    when i did the test i did rev the engine to see if at high rpm it would fail but still passed the test. I am going to take the rad off this weekend and have it testted by a radiator mechanic
  1. Cracked Radiator
    Last Post: 04/03/2013, 04:20 AM
  2. 160,500 k and a New Radiator
    Last Post: 07/22/2010, 05:27 PM
  3. Driving problem fixed/TOD problem realized
    Last Post: 02/26/2010, 06:57 AM
  4. Radiator
    Last Post: 04/22/2008, 06:36 PM
  5. Aluminum Radiator
    By MachineVX in forum VX Modifications...
    Last Post: 06/22/2005, 05:56 PM
