Results 1 to 4 of 4
Thread: Water in power steering fluid?????
    2000, Kaiser, #0016
    How the hell does this happen?
    I do have a small slow leak, but Ive just been topping off the PS fluid to compensate. Today I noticed the fluid in the reservoir had a milky color indicative of water! WTH?
    I know I need to purge the system, but how critical is this and where could it have come from? Any ideas?
    Nov 2007
    1997 SILVER
    Depends on where your small leak is.
    If it is down low where it can get wet from road spray, the PS gets hot as you drive, then cools down. Water sitting around your leak can get sucked in as the temperature changes and the colder fluid reduces in volume.
    That is an old problem with agricultural machinery.
    PK
    2000, Kaiser, #0016
    Intresting, the leak indeed is down low. Thanks PK.
    2000, Kaiser, #0016
    Thanks Mark, that's another interesting point.
    I have been topping it off with Dextron III, but have no idea what was in the system before.
  1. I noticed my power steering fluid leak...
    Last Post: 03/27/2015, 09:50 PM
  2. Power steering fluid leak!
    By jdm monkey in forum VX Troubleshooting...
    Last Post: 10/19/2012, 07:52 AM
  3. Leaking Power Steering Fluid
    Last Post: 11/10/2008, 06:50 AM
  4. Power Steering Fluid
    Last Post: 09/05/2006, 11:02 AM
  5. Brake Fluid vs. Power Steering Fluid
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 07/01/2006, 04:12 PM
