Alright had a little delay in getting my stock rims powder coated but everything is lined up for next week. Finalizing color ideas Friday.
Thread here: http://vehicross.info/forums/showthr...ghlight=powder
On the stock rims (powder coated) I want to run 33s M/T tires.
Right now I am pretty set on these: http://www.treadwright.com/p-72-285-...ard-dog-d.aspx
But before I bite the bullet I wanted to see what others thought and could share about a couple questions I have.
The tread looks similar to the older Wrangler MT-R, which if I remember right is what Jay Dunford ran?
I currently run 265/75-16 AT (Dakota - Pep Boys)
1. This will be a heavier tire but stiffer, how much performance will I lose, given that I have stock gears? These are 65lbs.
2. Anyone with a similar set up care to share how much it affected gas? If it does a lot I will probably be forced to start driving another car as my DD or split time instead of 100% VX (which I don't like the sound of!)
3. At $190 each it is a GOOD price for this style of tire but the 265/75-16 is almost half the costs $110. Not sure but I think in the long run I will not be happy with the 16 version and still want to go bigger.
4. With the stock rim and about an inch or so of tire, think I will have much more to trim or hammer out? I forget my offset now but it sticks out a bit but not much. (4.5 backspacing kinda sounds right).
- Really just trying to bring anything to the surface that I may not realize till I put them on. And I may get a spacer and crank a bit more (do have my diff dropped).
Thanks in advance.
