Results 1 to 10 of 10
Thread: engine won't turn over
    Jun 2010
    2000 Proton VX 0630
    Has anyone had their ignition go bad on them?
    As of now, when I turn the key all I hear is the pin disenaging from the starter, but the engine will not crank over.
    Does that sound familiar to anyone?
    btw... battery is ruled out. It's plenty strong
    '01 Ebony #0939
    I'd be more inclined to think it was a faulty starter/starter-solenoid. If you can actually hear something in your starter clicking, that means your starter relay (in the engine compartment fuse box) is working, so maybe the coil for your starter solenoid is bad?
    Sep 2009
    2000, Foxfire Red Mica
    It's worth checking the leads to the battery--mine were pretty corroded and not making proper contact. There was enough contact to allow for things like the door remote and the light when I opened it, as well as a click from the starter, but not enough to draw the power necessary to start. After a quick scrape with a pocket knife it started up no problem, and I've had no issues since.
    Feb 2010
    2001,Kaiser,1130
    Quote Originally Posted by Hiredgoon View Post
    This exact same thing happened to me. The battery connectors had enough current/contact for accessories but not the ignition.
    Nov 2007
    1997 SILVER
    I have noticed that the factory battery terminals are slightly on the large side and after removing them a few times the batteries lead terminals wear out enough to not make a solid contact.
    Jun 2010
    2000 Proton VX 0630
    I replaced the battery first, have checked/double checked the terminals/leads... all is ok there.
    Maybe replace starter fuse in engine compartment? We all want it to be the most cost-effective, right?
    Not really lookin' forward to removing starter to have it check out...doesn't look like there is much room around there.
    after all, I'm a retired bodyman, not a mechanic...... me no likey that stuff
    May 2010
    1999 Ebony 1716
    Instead of removing the starter, tap it gently with a hammer or handle of a screw driver, anything with a little weight on it, while someone tries to start it, if it starts then the starter is getting old and sticking. It's a freebee check. Give it a few raps and try to start at same time, if it doesn't work try a few more times with a few seconds between each cranking attempt and tapping.
    Wrench
    Quote Originally Posted by Luna X View Post
    I hear ya cluck'n red rooster...
    Back in the day, before I picked up the evil again, I drove my 88 Toy PU for almost a year with a non functional starter.
    However, I had two (or one, depending on the terrain of your usual range) advantages, a manual trans, & an almost unlimited supply of hills to park on.
    After the evil was picked up again, I had it changed out in a matter of hours...WITHOUT having to jack up the engine.
    But I did invent new swear words & theories to describe the parental lineage of the Toyota engineering team that stuffed the starter "way the F up there"...
    Jun 2010
    2000 Proton VX 0630
    After reading some older post, it does seem possible that my little oil leak could be the culprit...oozing it's way to the contacts.
    Hopefully I can get under there tomorrow and do some better investigating.
    It's too bad that a little red light would just appear and point you to the problem...
  1. Need help vx won't turn over
    By subject47 in forum VX Troubleshooting...
    Last Post: 03/19/2013, 12:19 PM
  2. Now it's my turn....
    By Gussie2000 in forum VX Troubleshooting...
    Last Post: 01/26/2012, 08:11 PM
  3. Now it won't turn over
    By DK in forum VX Troubleshooting...
    Last Post: 05/16/2005, 11:11 PM
  4. turn off TOD?
    By marximus in forum VX Talk...
    Last Post: 12/31/2004, 06:33 AM
  5. Replies: 1
