So, I found a small puddle of red fluid on the garage floor the other day. Turns out that the TC (large one) pan's gasket is leaking a bit. So after a bit of research, I have a few questions that I hope someone can verify or enlighten me before I tackle this.
1) In order to remove the cross member, where EXACTLY would be a good spot to support the transmission? (refer to pic down below)
3) This appears to be the cross member needs to come off to remove the TC pan? (refer to pic below)
4) Since I'll have the pan off, I might as well replace the filter (screen) while I'm at it. Planning to go to Autozone to purchase the filter. I read that the pan gasket comes with the filter?
5) Once everything's all cleaned, replaced, and re-assembled, I refill with Dexron III (6-7 qts.?), have the truck running, shift through all the gears, and top off with more (still while truck is running) if needed?
Thanks for any feedback/input in advance that you can provide. rudy
