Results 1 to 15 of 15
Thread: Bolt size for rear seat.
    Jun 2011
    1999 Astral Silver VehiCross #0510
    My VX got here today, and the A$$hat of a dealer didn't tell me that the front mounts for the rear seats are not secured. I found out when I went to pull up the right rear seat from the cargo door by the strap, and the entire seat came with it.
    What size bolts do I need to fix the seat back in, and will it need any more than a standard wrench?
    Thanks!
    Oct 2011
    1999, Black, VX, 9999
    anybody have this answer or a pic of the bolts for backseat?? I just bought a used seat and now need to install.
    houser,
    If you look in the shop manual available in the download section, that bolt is called the 'Rear Seat Hinge Fixing Bolt'. Pix are on pages 8G-4
    It looks like the parts manual lists it as part# 89438 46970 if you wanted to try to order some from Merlin.
    I'll see if I can pull one of mine & run by Lowes to see what size it is.
    Jun 2007
    2001, Proton
    You canorder from
    Merlin that way you not only have the right size but right thread and strength.
    Carter Pewterschmidt
    Well, give me some credit. I'd make sure I gave him the right pitch when I determined the size
    Feb 2009
    1999,silver, 1516
    If I'm not mistaken, some members have used some sort of similar sized pins to replace the bolts. That way if they want to remove the rear seat it's as simple as pulling two pins. A search will probably yield the thread where the proper hardware was discussed.
    Yah, those bolts are the ones that run through the hinge though. He's looking for the bolts that attach the hinge to the floor.
    Since his seats are currently discombobulated though, now would be a good time for him to make that conversion.
    Feb 2009
    1999,silver, 1516
    Gotcha. Missed that detail the first time through. Thanks
    Actually, it could be either bolt that he's missing. I'm assuming that it was the bolt(s) to the floor. I could be wrong but I'll never admit it. Hopefully he'll check in soon and let us know which.
    Oct 2011
    Thanks everyone! I got lucky at autozone and found a mix pack of bolts/nuts for Asian cars. After forcing all the rust out by using a rubber mallet with the rachet, they went in pretty easily. I will post sizes when I get home. And it was the bolts for the hinge to floor, not the pin inside the spring. Also the seat design with all the options and ability to fold out of the way is the best I've seen!
    Jul 2009
    Since his seats are currently discombobulated though, now would be a good time for him to make that conversion.[/QUOTE]
    Discombobulated, I've always liked that word...so discriptive!!
    Vixer Fixer
    Discombobulated, I've always liked that word...so discriptive!![/QUOTE]
    Yah, but the question of the day is: did I spell it right???
    Jul 2009
    According to Merriam Webster you did, and he knows everything!!
    Eye tat im wale!
    Jul 2009
    Woy, 'at ye did mate...
  1. License Plate Bolt Size
    By Child's Play in forum VX Talk...
    Last Post: 06/25/2011, 08:35 PM
  2. Front Seat Belt Torx Bolt
    By darkl4805 in forum VX Troubleshooting...
    Last Post: 12/10/2006, 04:51 PM
  3. Bolt size
    Last Post: 09/12/2006, 10:56 PM
  4. wheres the rear seat belt bolt go?
    By -x- in forum VX Troubleshooting...
    Last Post: 06/02/2003, 12:29 PM
  5. Broken rear seat bolt -- how to get the broken piece out?
    By Grant Eaton in forum VX Troubleshooting...
    Last Post: 04/01/2003, 05:50 AM
