Originally Posted by
Mark I do recall now you were installing that in the Stoop fix-it-lot...did you buy new OEM or aftermarket new?
Thanks all for the input!
Sue, the mechanics felt bad about trashing the sensor so they gave it to me at their cost (still $380ish) with no mark-up, and since I installed it myself there was no labor involved. The part you buy is actually the sensor, it's wire up to the connection right behind the top of the shock, and two or three brackets that hold the wire out of the way. It's still a rediculously expensive part for what it is AND I ended up removing (and reinstalling) one of the brackets to snake the wire where it needed to go and had to shave down one of the other brackets to get it all to fit in correctly. I didn't think about it, but I should have done what Buffy did so that it wouldn't weld itself in there again. Maybe I should get on that now while it's still fresh.
As a slight thread jack; what would be the "right" thing to do when one of these mechanics breaks something to get at what you wanted them to fix in the first place? Who would have known that the ABS sensor would fuse itself to the front hub assembly, and would break as you try to pull it out? Should they be on the hook to pay for something like that, or is it just expected for some things to go wrong as you get in there to fix other stuff? If I had been doing this repair and trashed the ABS sensor I would have had to buy a new one, but if they trash it should they pay for it?
I'm a little up in the air about it.
