Thanks etlsport for your insight. That's what I'm trying to achieve. When you turn ON your headlights, then the drls would turn OFF. As I mentioned to Ldubs reply, I'm inorporating seperate led lamps instead of tryng to convert the head lights to drls. I liked your idea of using the e-brake. But, as you said, it'll remain ON even when you turn on the headlights. Really hoping that I can keep that from happening. Do you think my set up won't work w/ seperate led lamps?
