Results 1 to 7 of 7
Thread: White Front Turn Signal Lenses Covers
    Nov 2008
    2001 3,5L gray supercharged
    Cool White Front Turn Signal Lenses Covers
    Hello all,
    can someone tell me where can I buy WHITE FRONT TURN SIGNAL LENSES COVERS ?
    Many thanks prom Italy
    P.S. In italy there is only one Vehicross........mine.
    piluf@libero.it
    Apr 2011
    1999 Ebony 0038
    Ron sell them I just ordered a set for myself fast shipping great product
    "$20/set Clear Front Turn Signal Lenses LOTS LEFT!"
    http://www.vehicross.info/forums/showthread.php?t=20199
    Good luck!
    David
    Rolling around the pacific northwest ...
    Feb 2010
    2001,Kaiser,1130
    I ordered them from Ron and they are a bit off (where the holes are drilled). They are also just clear covers, so they don't bend around and seal the turn signal like the stock ones, so if you have inclement weather I can see that being a problem. Just my 2 cents.
    '01 Ironman #1109
    Quote Originally Posted by atilla_the_fun View Post
    Been through all sorts of weather including minor flooding with mine for years and no issues. FYI, the OEM's are not waterproof/weatherproof. Just my 2 cents.
    In any case, I'll be offering Klearz lenses (we go way back) for the VX as well as mine when I get my site up and running soon. This way you'll have options to choose from.
    www.aftershockproducts.com
    Sep 2004
    2000, Ebony, 0786
    Ron, I got a pair of front clear lenses from you a couple of years ago. The fit was perfect and no weather issues at all. Thanks. BTW, anyone know where I can get the front side markers darkened? Klearz maybe? I tried ClearCorners out of CA but they won't return my calls or e-mails. I've tried them on and off for months. I want to go darker on everything up front. Headlights, as was done a few weeks ago, front turn signals and side markers.
    Raider
    Mar 2010
    2001 Ironman 0588
    Klearz is a source in Canada and they ship internationally. I hear their front lens covers are very good (located in the cladding below the headlights.) I just got their side marker lenses/housing (for the front fenders) - quality is a little shabby and they required trimming so they would fit.
    Mar 2010
    2001 Ironman 0588
    Yep, Klearz has smoked lenses, too. They sell the lens by itself and you have to cut the old lens out of the original housing -or- you can buy a lens with a poor-fitting new housing. The latter will still require that you use a Dremel tool (or something) to sand away the excess plastic and high spots and modify the center of the housing so it fits. Very tedious (sand, test fit, sand test fit....) Trying to cut out the old lens and glue in a new one sounds like it would be an even bigger headache. I wonder if a spray on tint would be a better solution for you.
  1. turn signal relay ??
    By orion in forum VX Troubleshooting...
    Last Post: 07/13/2014, 09:23 AM
  2. turn signal help
    By dsallade01 in forum VX Troubleshooting...
    Last Post: 06/28/2011, 07:44 AM
  3. front flasher - turn signal not working, no power - rapid flashing of rear
    By atilla_the_fun in forum VX Troubleshooting...
    Last Post: 03/17/2011, 05:38 PM
  4. Tail Lamp Covers - Clear Lenses!
    By Sederburg in forum VX Modifications...
    Last Post: 12/20/2010, 07:11 AM
  5. LED Front marker & Turn Signal Mod
    By Tookie in forum VX Modifications...
    Last Post: 09/26/2010, 03:29 PM
