Results 1 to 15 of 15
Thread: VX just died on interstate... ideas?
    99'/astral silver/vehicross
    So, I got a small contract job, and of course on my second day my otherwise perfect VX decides to go crazy. So I'm on the way to work, interstate, and doing about 75-80. All of a sudden it's like the transmission isn't in gear... Like it just starts to coast down, I can give it gas and it doesn't seem to be in neutral, but it's also not pulling at all. I put my hazards on get to the emergency lane and shift her into park. Immediately dies completely.
    I sat there for a second, started her up and put her in gear. Drove normal the rest of the trip. I don't understand it at all, but of course I'm uber paranoid now.
    It was nothing like the EGR issue we often experience (and I already fixed) the VX didn't completely die until I came to a stop. It feels like an electrical issue with the tranny, but I have no idea where to start since this is my only automatic ever and I've never had to work on the tranny. Ha!
    Any ideas from the group? Thanks in advance guys.
    - David
    macintosh man
    Feb 2009
    1999,silver, 1516
    My first guess would be fuel pressure regulator. Mine would randomly die and hasn't since replacing the FPR.
    We've been having an insane heatwave. I wonder if that could be the cause if it's the fuel pressure regulator.
    Mine used to do that a while back...turn out i didnt seat the fuel cap properly and had vapor lock. Worth a try before spending any money. When I loosened the cap I heard a pssss sound.
    May 2011
    '93 White Trooper, 00 VX
    fuel pump maybe? should be some thing about the fuel
    '93 Trooper 3" lift 32"s. '00 VX
    '01 Ebony #0939
    Given how you say things happened, I'd also suspect the problem to be fuel related, and everyone else who's responded have already covered the suggestions I'd have made.
    Just curious, what was the ambient temp at the time?
    exactly what happened to mine about a year after i bought it. i replaced the fuel filter and fuel pressure regulator and never had a problem again
    Thanks for the advice guys... It was about 90 degrees already when it happened.
    Strangely it was fine the rest of the way to work and on the way home in even hotter weather.
    It sucks because Im pretty broke so it's hard to go replacing fuel line parts without really knowing... It was just a really crap experience having it happen in traffic at 80mph in a five lane situation. Hahaha.
    I hope it happens again in less compromising circumstances so I can pay better attention. I was just trying to get across five lanes safely while attempting to listen to what was happening.
    It does seem like fuel though since anything transmission related probably wouldn't make it shut off completely once I'm at a standstill.
    Anyway, I'll see what happens tomorrow. I'm gonna stay in the right lane this time. Haha.
    Cheers, and thanks for all the info and advice everyone.
    - David
    Dec 2010
    1999/White/Ironman VX/0940
    Almost the same thing happened to me when I first bought my Vcross back in december. I was in the far left lane on a 5 lane highway leaving atlanta GA. 20 miles away from the dealership I bought it from all the sudden no power at all like it was in neutral and had to coast across all 5 lanes and coast into a cracker barrel parking lot. Turns out my 3rd and 4th gears were completely burnt down to nothing because all of my tranny fluid had poured out because the mechanic forgot to hook the lines back up.
    Feb 2009
    1999,silver, 1516
    Here's a decent price on a FPR from ebay: CLICKY
    Less than 50 bucks.
    Quote Originally Posted by technocoy View Post
    - David
    2000, Ebony, VX, 0370
    Thanked: 12
    Both the fuel filter and fuel pressure regulator are relatively inexpensive and are EASY to replace yourself. The fuel filter is located on the inside of the frame rail just behind the passenger door. It may take a little persuading to get the lines off of it, but still shouldn't be a problem. There is a write-up by former member "Dino" on how to replace the FPR: http://www.vehicross.info/forums/showthread.php?t=12021
    I have the cut down allen key that his instructions call for that I would be happy to send you if you would like.
    '01 Ebony #0939
    Quote Originally Posted by Exclamation View Post
    Holy crap!! If that had happened to me, I'm not so sure that the VX.info User ID I'd have come up with wouldn't have been Expletive!
    Thanks guys.
    As long as it's not the fuel pump. I guess I could do the regulator and filter just as preventative and see how it goes. I mean, it's at 85,000 so I imagine some of these little bits will start to come up now.
    Thanks for all the help.
    MSHardeman, I'll definitely let you know if I go to do this. Thanks a ton for the offer.
    samneil, thanks for the link. I may just go ahead and grab this.
    May 2011
    1999, silver, 1234
    I replaced the FPR today using Dino's awesome instructions. I cut the allen wrench too short, but used a stub with a 1/4" wrench and a deep-well socket as a pry bar. When I got the old FPR out, I noticed it's screen had some residue in it. Also noticed the FPR vacuum hose was cracked at the FPR and at the manifold connection. Bought the FPR from Advance Auto Parts for $41.99 and it included a new snap-ring, which I am glad since I hate reusing snap-rings.
    Aug 2005
    1999, silver, 0887
    Water in the gas???
  1. Transmission DIED!!
    By UWVX89 in forum VX Troubleshooting...
    Last Post: 11/19/2013, 07:04 AM
  2. VX died Help....
    By bcbike in forum VX Troubleshooting...
    Last Post: 12/03/2012, 06:32 PM
  3. my engine died
    Last Post: 03/30/2011, 07:11 AM
  4. Hmmmm......ideas....ideas...
    By JAMAS in forum VX Talk...
    Last Post: 11/04/2009, 12:32 PM
  5. VDU has died.
    By BigDave in forum VX Troubleshooting...
    Last Post: 04/17/2007, 07:16 PM
