Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: clunk/tap feeling under my feet.
    Sep 2010
    2000,Ebony,VEC,0013
    If it is any consolation I have exactly the same issue. Right under the drivers side floor boards. I haven't found where it comes from and have lived with it for 6 plus months. I think of it as a transmission line bumping the floor or a loose bracket some where. There is driveline clunk too but it is a seperate thing...this is different.
    Dec 2007
    2001, KAISER SILVER METALLIC, X74, 0768
    I'm wondering if this is contagious since my VX is now experiencing the same noise. I really hope it's a transmission mount bolt that I haven't found because I swear it sounds/feels like a slipping transmission. I also notice a barely perceptible drop (about 100) in RPMs that coincide with the clunk/tap/pop.
    "going in when all others are running out"
    Dec 2003
    Former Owner 0216
    Quote Originally Posted by TOKKA View Post
    I went to install an aftermarket grill insert and found the rest of my tube bumber, behind the cladding rusted and moving around. I thought that might have been it, but it wasn't. However, it did take care of another noise I had when I turned and hit a little bump or something... I had a little thud.
    So.... the tapping under feet still continues. I have had the front end gone over by Firestone and they can't find anything. Valvoline oil change guys looked too.... couldn't see anything. So.... for now and until something breaks, it is what it is.
    I have the same noise now, especially when going over a bump--right under the drivers feet area. Was thinking it might be a bad shock or arm but I put mine up on the ramps and can't find anything loose or broken. Anyone have a pic where they can circle the possible loose tranny bolts I can't seem to find on the crossmember? (duh) Maybe a few arrows on areas to check...
    -Wekilled
    douglaswekell(at)gmail.com
    Heres a thread with tranny bolt pics, I need to check mine too.
    http://www.vehicross.info/forums/sho...nsmission+bolt
    2000, Ebony, VX, 0370
    Thanked: 12
    I don't know what the noise is, but be sure to check everywhere as noises and vibrations can really travel through our little car. When my drivers side inner CV race was going bad all of the vibrations and grinding that I heard/felt, seemed like they were coming from right under my feet. Because of that I thought it might have been transmission/transfer case related, but it ended up that the vibrations where traveling from the solid mounted center section of the front axle, through the frame, and I was feeling it right under my feet.
    Much appreciated. I hate having a problem that outsmarts me. I have put it up on the ramps twice and it is driving me crazy.
  1. Feeling charitable?
    By nocturnalVX in forum Chit-Chat ...
    Last Post: 11/16/2012, 06:21 PM
  2. Does yours clunk??
    By vx2001 in forum VX Talk...
    Last Post: 03/04/2011, 01:39 AM
  3. Brake Clunk
    By haggisgood in forum VX Troubleshooting...
    Last Post: 06/16/2010, 06:20 AM
  4. The clunk thing
    By MoonRaker in forum VX Troubleshooting...
    Last Post: 03/25/2009, 10:04 PM
  5. Feeling depressed about my VX
    By Lease-V-cross in forum VX Talk...
    Last Post: 11/05/2003, 03:18 PM
