Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 46 to 60 of 171
Thread: About a hitch?
    Sorry, I misinterpreted what you were asking. I thought that you were asking which of the two links you posted were what we've been calling the Tone upgrade.
    Anyone know which is the correct mount for the curt hitch?
    Outside: http://www.etrailer.com/Trailer-Hitc...cleid=20009025
    or
    Inside: http://cgi.ebay.com/ebaymotors/1999-...ht_6667wt_1034
    Sorry, I don't know. Maybe PM SilverBullet. I think he's the most knowlegable about the Curt design.
    Quote Originally Posted by Luna X View Post
    I went with the Curt hitch.... I know, I know it gives the "filled diaper" look as Tom4bren as mentioned but.............
    I crack myself up sometimes. Mom always told me though that I think I'm a wit ... & I'm half right.
    in my many years of R & I bumpers, I have never seen ones so whimpy!
    I don't know how they even passed the US 10 mph standards.?.?
    Actually, the parts in Tone's design are uber strong ... it's what it's mounted to that doesn't 'cut the mustard'.
    So, if you are just gonna use it for a camping grill holder or step bar, I would go with the strength of the Curt that bolts to the frame rails.
    "That's my story, and I'm stickin' to it"............
    I have no response to that
    Jun 2007
    2001, Proton
    mine goes to the outside
    or
    not sure if the inside works as well but the outside is easier to mount
    Carter Pewterschmidt
    2000 IronMan #11
    I talked to Welder Guy last night. I'm supposed to hook up with him next Thursday or Friday for him to fit check the new design (& to locate the tabs for the cladding bolts). Will keep you posted.
    99 Silver 515
    Pictures
    Please do, anxiously awaiting the next generation of tow hitch. Can you snap a picture when you see it???
    Dan
    sure, but it'll be ugly. It'll still just be tacked together & not fully welded.
    Jun 2010
    99, Silver, 1784
    I'm wondering if the hitch will fit the same notch in Rowhard's fiberglass rear skid plate. Any good info on that would be greatly appreciated!
    -V
    1999, Ebony Black, VX, 1614
    -V
    I dont want to speak for him, but I believe Tom will make sure the hitch fits in his existing "slot" already cut out for the Tone style hitch. So if its in the same position as before, I would say it will fit the same notch in the Rowhards fiberglass rear skid plate.
    That's the plan (read page 2 of this thread).
    I planned on spending about 2 hours with Welder Guy on Friday (I had lotsa honey-do's that the rest of the day was scheduled for).
    Instead, I spent about 9 hours in his shop. This is what we learnt:
    Rural Virginia has lotsa 'good ol boys' stopping by throughout the day with beer in hand willing to "help".
    Things behind the cladding are much tighter than I thought they were. Everytime that we adjusted the design to eliminate an interference, another came about. After about 6 iterations of the design, we think we have a viable product.
    The cut out in your cladding (for the original Tone hitch) should still be correct.
    The receiver will protrude approximately 1/2 inch further than the original. This should be a good thing though since some were having problems installing a locking hitch pin.
    We may be able to retain the tube bumper but the tabs for the cladding bolts will have to be cut off. Of course, I already cut mine up thinking that we wouldn't be using it anymore.
    We will lose both of the rear snatch points. Sorry ... you'll just hafta get a receiver Mr Scary Hook from Harbor Freight. The right side snatch point uses 3 bolts that we need to use. The left side only uses 1. Since we are going for strength on this design, 6 mounting bolt features are worth the loss of the shackles. We'll have 2 vertical bolts and 4 horizontal.
    It will be made from 2" thick wall steel square tube. It's going to be heavy so shipping cost will be more.
    Welder Guy will try to have the first prototype fully welded in a week. He's keeping the tacked version as a shop queen to use for comparison till the process is locked in.
    I took some pix. I'll get them posted later today.
    As promised:
    Shows everything removed for installation.
    Shows all that's left of the tube bumper (had to retain that part for side cladding bolts)
    New hitch (just tack welded so far - spacing and angles later changed)
    Hitch held in place with jack & cladding held on with 3 bolts.
    Hitch without cladding. Right mounting plate missing (it was a BFH thang - you wouldn't understand).
    Looking good.
    how hard was it to remove the bolts that were holding the snatch/tie-down points?
    17mm box end with a 2' piece of PVC for leverage.
    It was suprisingly easy considering the age, mud and fine threads.
    I just re-read your question & see there is more to it than I originally thought.
    You CAN remove the one on the left (driver) side without removing the rear cladding. You MAY be able to remove the one on the right (passenger) side without removing the rear cladding but you'll have to be a contortionist.
    Your original reply answered my question. However, that is good to know about having to remove the cladding.
  1. ISO Tow Hitch
    By Lizardmen3477 in forum VX Modifications...
    Last Post: 09/30/2014, 06:57 AM
  2. JDM Hitch
    By The Claw in forum Japanese Domestic Model (JDM) VXs
    Last Post: 02/08/2014, 02:49 PM
  3. UK Tow Hitch
    By crotchrocket in forum United Kingdom Special Topics
    Last Post: 11/07/2009, 11:44 AM
  4. Tow Hitch....$139
    Last Post: 04/16/2007, 01:08 PM
  5. Used hitch
    Last Post: 07/04/2005, 02:28 PM
