Wierd
The install is very easy but I did run into one small SNAFU
The external C-clip has to be replaced. The groove used with the OEM slug is up on the splines. The one you need to use with the hubs is further out on the shaft. I assume if you buy a new set, it comes with the new C-clip. I bought mine used so didn't know till the VX was taken apart.
Fastenal had what I needed in the store. I still have the bag if anyone needs the part number.
