I've been noticing that there is an excessive amount of grime built up on the top of my engine (i think they're called the cylinder heads?) - around where the spark plugs go in. My guess is that some oil is seaping out from somewhere, but I can't really determine where, unless it could be from around the plugs. Can someone tell me where this is coming from, and what I need to do to fix it?
I'm not sure if it's related, but I've noticed that the performance has been declining a bit in the past few months, despite a few performance mods (PV Muffler, Cone Filter).
Any advice would be appreciated!
Never had a problem, but then I use good common sense and avoid getting electrical components too wet and avoid geting degreaser on belts, hoses and other ruber parts, just the oily metal parts the need degreasing. Hope that helps
