Results 1 to 2 of 2
Thread: Offroad Lights wiring issue
    I just re-wired the lights on my roof, there are (4) 55w halogens.
    They are on two seperate switches which trigger 2 separate 30amp relays.
    The setup is..
    (2) 12ga wires run through my aux fuse box, 25amp fuses on each. those run directly to the relays, located behind the glove box. from the relays each light is wired individually, so (8) 16ga wires (4 power 4 ground) run to the back of the vx, out the spoiler and up to the lights. The wires are all contained within a 4ga jacket (its a 9 conductor power wire for audio install) they are grounded on separate ring terminals to the factory ground located behind the passenger side kick panel.
    when i hit either of the switches, all 4 lights come on somewhat dimly. When i hit the second switch they all go to full power. They are supposed to just come on two at a time. If i disconnect the ground from two of the wires, only the other two will light up. If i disconnect one of the relays and give power to the other, all 4 lights come on. if i skip the relays all together, supplying power to 2 lights will make all 4 come on.
    ... im stumped
    2001, Ebony Black, 1153
    Sounds like a ground problem unless you just crossed the wires up on accident. I would try groundeing one pair of the lights somewhere else to a good frame ground. Probably not good to ground that many things to one area, it would make sense that for the pair that should not get power (with one switch on only) the path of least resistant to ground might be back up and around the other set of lights and thus turning on all the lights since halogen bulbs are not polar specific.
  1. ABS issue and fog lights
    By VehiBRO in forum VX Troubleshooting...
    Last Post: 04/18/2014, 08:14 PM
  2. Rear fog and front fog lights wiring
    By David Wiltshire in forum Japanese Domestic Model (JDM) VXs
    Last Post: 07/07/2013, 01:40 AM
  3. Best Offroad Lights Ever?
    Last Post: 07/04/2010, 11:05 PM
  4. offroad light wiring
    Last Post: 10/25/2007, 03:54 PM
  5. Question about the wiring harness for fog lights
    By Arachnid J in forum VX Troubleshooting...
    Last Post: 06/26/2005, 08:31 AM
