I just re-wired the lights on my roof, there are (4) 55w halogens.
They are on two seperate switches which trigger 2 separate 30amp relays.
The setup is..
(2) 12ga wires run through my aux fuse box, 25amp fuses on each. those run directly to the relays, located behind the glove box. from the relays each light is wired individually, so (8) 16ga wires (4 power 4 ground) run to the back of the vx, out the spoiler and up to the lights. The wires are all contained within a 4ga jacket (its a 9 conductor power wire for audio install) they are grounded on separate ring terminals to the factory ground located behind the passenger side kick panel.
when i hit either of the switches, all 4 lights come on somewhat dimly. When i hit the second switch they all go to full power. They are supposed to just come on two at a time. If i disconnect the ground from two of the wires, only the other two will light up. If i disconnect one of the relays and give power to the other, all 4 lights come on. if i skip the relays all together, supplying power to 2 lights will make all 4 come on.
... im stumped![]()
