Results 1 to 6 of 6
Thread: CV Question
    CV Question
    Out of all the times I've replaced the CV boots, I've never had to disassemble the Outer CV. Now I need to. How do you get the guts out of the outer CV? I can't see any kind of a retaining clip ... but there has to be one.
    2001, Ebony Black, 1153
    You probably have th cv totally out of truck right? Bearing cover off (Allen head bolts) and c clip snap ring off, push cv through to inside?
    Well the center shaft just pops into place. I took a hammer to the outer cage while having the smaller outer green cup clamped down and the shaft pops out. As far as getting the outer cage and balls out I don't know. Is there a retaining ring like the inner? I have never had problems with the outer. Have you thought about just getting a new generic one? Or finding a nice used one?
    The outer on the drivers side exploded a few months ago. The axle shop needs the small shaft from the passenger side to rebuild my spare set. That piece was missing when I got the parts back from RCV.
    I can't see any retaining clip on the outer but I know there has to be one. I'll hit it again tomorrow.
    Just an FYI...my Empi's survived the beating I gave them in Moab!
    Feb 2005
    01 Kaiser Silver
    Tom I had the same problem with trying to get mine off. Reading various "different forums" you either rotate them just right or clamp the shaft down and BFG it. I am not sure which axles you have as I had lame EMPI axles installed. Crap I cant find them darn links or how I googled it. I will try and find this weekend. There was no pictures/video all I could find was discussion.
    I'm taking it to the axle shop in the morning. They already have 2 with the shaft removed so I'll just swap with them (prolly save some effort since the outter will not have to be rebuilt on that side.
  1. Replies: 7
    Last Post: 01/28/2004, 11:38 AM
