Results 1 to 15 of 29
Thread: 99 w' FFD Electric Twin Fan setup
    Dec 2002
    1999, Silver, VX, 1623
    Coolant is less than 1 week old. I replaced it when I put the fan kit on.
    Electric fan in front of the condenser, right behind the grill is present and comes on when it should.
    It is a twin fan setup in a very nice shiny aluminum TIG welded shroud. Goes on the engine side of the radiator. Looks great, doesn't work as well was the fan clutch setup.
    Fully vented hood would help considerably. It gets real real hot under the hood.
    John
    99 Silver VX
    May 2003
    2000 Ebony VX 0577
    If it is still overheating you said you mounted it on engine side. I hope its a pull fan not a push. Many people do this and mount push fans on engine side. Pull on engine side and push on bumper side
    I always take life with a grain of salt. Plus mashed potatoes and gravy!
    here is my setup, factory fan clutch on the engine side, works like a charm, of course I think hottest ive ever dealt with is sitting in bumper to bumper traffic in 102 degree weather
    Another thing that could help is to add more water to your antifreeze mix. water transfers heat better than antifreeze, so the higher water content the better, but at some point you start to lose corrosion protection and your boiling point will drop, so I wouldnt go past 60% water
    Apr 2011
    01 Kaiser #0806
    sometimes i wish there was a better fanclutch...not sure if it's just mine or all VX's sounds like an airplane....maybe larger electric fans and a 3 core radiator would do the trick.
  1. VX setup for towing
    By tom4bren in forum VX Modifications...
    Last Post: 04/27/2012, 08:10 AM
  2. Turbo Setup For Our Car? What ya Think About This One.
    Last Post: 11/24/2010, 04:29 PM
  3. Has anyone seen or used this twin fan setup?
    Last Post: 04/13/2010, 08:48 PM
  4. Twin speed supercharger
    By Andrey in forum VX Talk...
    Last Post: 07/20/2006, 07:40 PM
  5. V6? Twin Turbo-Just For Looks...
    By -x- in forum VX Modifications...
    Last Post: 06/23/2004, 08:08 PM
