looking at a K&N air-filter anyone have any input? I'm thinking about removing my air box and installing a K&N filter and maybe a possible stage 2 turbonater electric supercharger any input on that as well?
I use a drop in k&n and have been happy. Regular air filters are nearly as exspensive. Those electric superchargers are a total waist of money...you might as well wire your wifes hairdryer into it.
I used a drop-in K&N filter in my stock airbox before I installed my WeaponR setup. I was pleased with the K&N. Its major advantage being supposedly higher airflow rate and is intended to be cleaned and re-used as opposed to being replaced when its gets dirty. They have a special cleaning kit that costs a few extra $$, but the fact that your not tossing airfilters out when they simply get dirty might save a few bux in the long run.
I say unless your planning on making some sort of "shield" for around the filter and a bracket to support the tube, I'd just go with a drop-in K&N. The flow rate should be very close and as for gains on these trucks I'd say they'd be identical. Plus you have a sealed box. As for the electric supercharger, like already mentioned, don't waste your money.
thanks for the info K&N is probably my next step
I wouldn't use a K&N. Filtration is poor, and you run the risk of getting oil on your MAF sensor.
I have had my k&n in for about 4 years without any issues. I think as long as you don't over-do the oil you are okay. After oiling mine I set it out in the sun on a piece of newspaper to let any excess "melt" off before reinstalling it.
re: Turbonator... Definitely pass on that... What a joke!
re: replacing airbox w/ K&N... I'd vote "not" because the disadvantages outweigh the advantage. First of all, if you ditch the airbox you'll lose your Helmholtz resonator and second, unless you've modded to substantially increase HP (i.e., more fuel flow), the only real upside to a K&N is its reusability - and you end up offsetting that advantage with the cost of cleaner and oil - and most importantly - your valuable time!
If you decide to go with a drop-in K&N, you can have mine. Has about 20K miles on it. (if that matters) The previous owner had installed it. One of the first things I did was yank it out (for the very reasons BigSwede mentioned) and put an OEM in it's place. Didn't have the heart to throw it away though... It's yours for the cost of shipping!
I've got the Spectre long cone with a carbonfiber CAI intake. Works quite well. I also use Spectre's small cone breather filter. They look cool together, are very effective at filtering, create a nice sound when accelerating and are reasonably priced. I got mine when they were on sale at AutoZone. They're carried pretty much everywhere.
I have a K&N flat filter sitting in a box. Took it out after having multiple CELs for MAF codes. Haven't had a code since.
Gregg
2001 Proton Yellow #1379
