Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 35
Thread: Pictures of WELDED to frame Rock Rails please...!!!
    Feb 2009
    1999,silver, 1516
    I'll bring marshmallows!
    The major advantage of "pine sliders", is the fact that you always have a ready supply of firewood if absolutely EVERYTHING goes horribly wrong & you become stranded on the trail...
    1999, Ebony Black, VX, 1614
    Quote Originally Posted by Kenny View Post
    Thats kinda funny.....
    I use cardboard to get the correct fit for building boxes out of wood.
    So I guess it goes -- cardboard < wood < steel < Shaq
    Jo, are you doing the bending and welding?
    If all goes to plan....
    ...there will be no bending.
    I will cut and prep all the square tube, gussets and plates...
    ...then a pro welder is gonna stick it all together.
    At least thats the plan!
    Ah, gotcha! Thought maybe you had invested in a tube bender and welder...and I was going to have to come spend some fab time in SD!
    Tube bender and welder are on the wish list!!
    The square stock I'm using is easy enough for me to cut / mitre / prep etc.....
    ...but a pro welder seemed like a good plan for this, especially on the frame!
    Mar 2005
    01 Ebony - #0379
    Sorry if I'm being Captain Obvious here, but,
    Make sure you temporarily space the lower rail from your frame seam with something solid during placement. Its a PITA if the slider hits your frame over bumps when it's too close. Mine is a tad too close on one side, so during winter, ice gets wedged in there and makes some noise. I can think of a few rocks that could have pushed them up a few mils... Anyways, like you have to worry about snow.!
    Good luck!
    OK...so here are the finished Sliders...prior to painting.
    [url=http://www.vehicross.info/gallery/showphoto.php?photo=20699][/ur]
    They are kind of reversed relative to many I have see...with smaller square tubing running down the body seam and the larger rectangular tubing hanging a little outboard for 'edge' protection.
    Three mounting points to frame.....two beefy ones...and a less beefy, but but still STRONG one, tucked up under bar pivot at rear.
    Plates were put on frame to disperse heat effect of welding, and for crush strength.....tubes to frame were 'gussetted' for added OOOMPH !
    Going to coat them in bedliner...and beat the h*77 out of them in Moab!
    Looks super beefcake Jo!
    Look good Jo. But...it's going to be a beeeeeatch to sand the surface rust and paint them. Doesn't look like a lot of room to work on the tops (might just be the camera angle). I would just use flat rustoleum...they are going to get scratched...easy and cheap to repaint.
    Mmmmmmmm...BEEFY.............
    looks great jo. They look identical to the ones i built on the Runner, except with some 'prettier' welds
    I am running into the issue now that they have been on there for about a year and i am getting some rust on he upper side thats right near the body of the car, now i cant remove them to touch them up. Im going to have to come up with a way to get them off.....OR, even better yet, a 3" body lift would help me access them
    Wink
    Mmmmmm...i dunno, I think you guys are over think'n it...
    All ya need to do is...
    Reach on up there with some sand paper or a sanding block/sponge dealio, brush on some rust converter or primer, brush on some bed liner or undercoating/rust bullet...DONE!
    It don't have ta look purdy, we're not tAk'n it to the fair...
    Yup...........
    ...paint stick wrapped in sandpaper gets "up & in there", and a sanding sponge works well as Dub says.
    And hey, if I make 'em look prettier than me, they'll still be UGLY!
    Ya never know!
  1. Yakima Cross Rails for sale
    By Milevsky in forum Internet Parts Found
    Last Post: 01/11/2017, 11:51 AM
  2. bumpers and rails
    Last Post: 10/17/2014, 01:06 PM
  3. side rails and front and back bars
    By sabretooth717 in forum VX Modifications...
    Last Post: 03/17/2006, 05:06 PM
  4. Mounts FINALLY welded in!
    Last Post: 11/07/2004, 01:41 PM
  5. VX Frame
    By Medman in forum VX Talk...
    Last Post: 06/01/2003, 09:18 AM
