Results 1 to 15 of 32
Thread: Fuel System Issues?
    '01 Ebony #0939
    Low pressure on the fuel line could have also been caused by the Fuel Pressure Regulator being faulty, which is a common problem on VX's. A relatively easy replacement cost/procedure too. Irregular fuel pressures from a faulty FPR could have also caused the low voltage readings responsible for the codes you were getting from the O2 sensors.
    I don't know exactly what goes wrong with the stock FPR's on VX's, but given the mileage on the one you purchased, it's likely that the original is still in place, so it would be a likely place to start.
    Congrats on the purchase, and welcome to the site.
    Have them clean the MAF as well. Those symptoms were very similar to some problems I had when I first got mine (including running better with a full tank).
    2000, Ebony, VX, 0370
    Thanked: 12
    FPR replacement how-to:
    http://www.vehicross.info/forums/sho...or+replacement
    I used Dino's instructions and got the fuel pressure regulator replaced in not time with minimal knuckle damage.
    Sep 2010
    2001 kaizer vx
    got four Isuzus last year in the shop with codes for both O2 sensors. But the problems were - MAF sensors on two; on other two-someone forgot to tight the clamp at air intake hose to plenum - created air leak not counted by MAF sensor
  1. Help: How to Replace fuel lines going to the fuel rails.
  2. sound system issues (bad ground maybe?)
    Last Post: 10/02/2006, 08:53 AM
  3. Something sticking in fuel system
    Last Post: 01/21/2006, 12:41 PM
  4. P1171 Fuel System Lean During Acceleration
    By olsonjus in forum VX Troubleshooting...
    Last Post: 02/15/2005, 08:11 AM
