Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 67
Thread: Engine Swap
    Apr 2010
    What tcase are you using?
    Mar 2006
    2000 White Ironman 0160
    I will using ours.
    2001, Ebony Black, 1153
    Quote Originally Posted by WiSDoM View Post
    I will using ours.
    oh man I hope it can handle the increase in power.
    Apr 2010
    Ya but since he's using the 4L60E that's behind it it should be ok just needs a plate for the tcase so it can bolt up. I would try to get the H3 4:1 tcase and make that work, it's passenger drop!
    I wonder if the plate was in the $2,000 install cost?
    Mar 2006
    I thought the hummer tc was a driverside drop and that ours would just bolt right up.
    Apr 2010
    No they are weird and have a passenger side drop. And no the isuzu tcase pattern is not the same as the GM, it won't bolt up. And the Suzuki conversion isn't any easier than ours really. You could swap in a V8 fairly easy if you've done swaps like it before. Just pick the right motor combo.
    Apr 2010
    possible, I think that 4:1 case would be sick though. If they make a plate have them keep the dimesnions etc so we can see about mass producing it!
    Apr 2011
    01 Kaiser #0806
    wish they could do a isuzuconversion
    http://http://www.suzukiconversion.c...onversions.htm
    Apr 2011
    01 Kaiser #0806
    http://www.suzukiconversion.com/
    sorry bout that ...here ya go...4.3 vortec, 200r4 tranny, and not bad for the price to make a beefy sammy
    Apr 2010
    I'd go with a different trans but they build some cool stuff.
    Feb 2010
    2001,Kaiser,1130
    Seriously, I'd rather put the VW TDI 1.9L into the suzuki, that way you get 260lb/ft of torque (after ECU flashing) and 45mpg. I'd use parts from the jeep vw tdi kit on the VX, fab up the adapter plate and modified flywheel (or use the modified jeep one), use our tranny with an external 4L60E shift controller and run with it.
    Mar 2006
    Yah the tranny is 4l65e and I will be shopping for the h3 t/c NR6
    Apr 2010
    That'll be sick if you get that Tcase set-up. And I wouldn't bother with the 4L30E behind the TDI Atilla, why go through the work of swapping that motor in and leave the 4L30 behind it? Also the 4L60E controller wouldn't work with the 4L30E, they are completely different.
    Jan 2008
    1999 Astral Silver 0481
    According to wikipedia GM discontinued our VX's trans for a more reliable and better builted 5L40-E that features a 5 speed gearbox that is used in most BMW's 5 and 3 series sedans and SUV's
    Not sure if this new trans is suitable for our VX but worth looking into it
    Dakar was just the begining.
  1. LS4 V8 Engine Swap
    By Leon R in forum VX Modifications...
    Last Post: 02/28/2015, 06:39 AM
  2. What would be your dream engine swap?
    By VehiCrow in forum VX Talk...
    Last Post: 08/22/2013, 06:39 AM
  3. VX engine swap
    By dvo in forum VX Modifications...
    Last Post: 06/06/2010, 03:58 PM
  4. Has anyone DONE the axiom engine swap?
    By ilya in forum VX Modifications...
    Last Post: 01/13/2009, 08:49 PM
  5. Engine swap
    Last Post: 01/30/2007, 05:49 PM
