Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Engine suddenly dies...
  1. #16
    Jun 2003
    1999 Victory Ironman 1703
    Change the fuel filter and clean the MAF.
    The MAF could be bad or just dirty. Also check the EGR valve.
    I had this exact problem a few weeks ago.
    Then I had a high idle problem and changed the AIC.
    Jon
  2. #17
    Feb 2011
    2000 Dragon #0274
    It could also be a crank or cam sensor. Check the connections. If they fail or lose connection they shut down the ignition to stop damage. It will be like you just shut the key off. Not always but usually fuel will give you some sputtering even with fuel injection. EGR causes massive vacuum leak making high idle.
    Junster If it don't looked fixed.. It ain't fixed.
  1. Replies: 17
    Last Post: 09/21/2017, 11:15 AM
  2. Engine starts, then dies
    By crager34 in forum VX Troubleshooting...
    Last Post: 09/12/2017, 10:52 PM
  3. Engine starts up and dies
    By Baldwin in forum VX Troubleshooting...
    Last Post: 07/09/2016, 06:14 AM
  4. High Idle suddenly =/
    By Breezy in forum VX Troubleshooting...
    Last Post: 11/19/2011, 04:47 AM
  5. help vx dies while driving
    Last Post: 11/20/2006, 10:14 AM
