 Originally Posted by
vxfocus
				but the whole weight of the carrier case and diff has to help not to mention the gears that have to be turned even if the drive axles are removed the engine still is using horsepower to move the drive shaft then in turn the ring and pinion gears??
There's few things you can do to improve MPG.
Besides eric's suggestions i'll add a cold air intake,get rid of unecessary load in your trunk,keeping your tires @ the recommended PSI,have your VX's balancing/alignment in good stats and last but no least,using good fuel
				Dakar was just the begining.
