I replaced my master brake cylinder tonight. It comes with 2 disposable plastic bleeder screws which are used during the bleeding process. It is not to be bench bled so I bolted it in place and filled the reservoir. I placed the 2 bleeder screws on and then attached a one man bleeder kit to both ports on the screws. I turned the engine on but when I depress the brake pedal I get no action. No movement out the bleeder screws and no bubbles no nothing. I would think it would begin to prime immediately. Has anyone encountered this or done this before.?????![]()
