Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Thread: Headlight protectors
  1. #31
    Quote Originally Posted by RabidPony View Post
    Kat, the gap I was referring to was where that ebay kit has the sheet for the main body of the kit then the second piece for the horns. If that's what that second piece is for anyway. If you did it with a single sheet and used heat and application solution, you could apply the stoneguard to the light and shape it to cover the whole thing, horn included. I looked at your install thread, looks like you did a good job to me. Give it a few weeks and some of those lines and bubbles should either be less noticeable of go away altogether.
    Wow, you means there's still hope? That's great to hear. Can I still hit them with a hair dryer now (day, 5 I think) and try to get some of those small lines out? Or would that be a bad idea at this point? The outer side of the horn (on both lenses) has completely come loose, not adhering at all. I'm thinking it may be best to just cut that small section off.
    ...and the 2nd piece you're referring to I "think" is the cover for the turn signals. The headlight is all one piece.
  2. #32
    Oct 2009
    99 Astral Silver
    Yup, there's still hope. Make a mixture of about a cup of warm water and a few drops of dish soap and put it in a spray bottle. Get out the hairdrier and warm up the stoneguard a section at a time, also turn on the lights to help keep the plastic warm. You will also need something to smooth/work the stoneguard. I recommend the soft plastic plaster/bondo scrapers (pictured below). Warm the stoneguard with your hairdryer and spray it with the mixture then slowly work it with scraper. Go slowly and carefully and keep the stoneguard warm. If you do decide to peel them off and try again, send me a pm and I'll post some extra pointers.
    Oh, and you're right, I thought that other piece was for the horns.
  3. #33
    Dec 2010
    1999 WHITE IRONMAN 1207
    VX headlites
    We have uv protection on our headlights? Would never know from all the hazieness.
    You need to polish those baby! We do everyone of ours.
  1. Headlight adjust
    By LukeVX in forum VX Troubleshooting...
    Last Post: 11/10/2011, 07:33 PM
  2. Headlight removal help
    By BlackVXer99 in forum General Tips...
    Last Post: 02/26/2009, 10:57 PM
  3. Roof Rib Protectors
    By k4tmc in forum VX Modifications...
    Last Post: 10/27/2006, 06:42 PM
  4. headlight fix, yet another
    By IndianaVX in forum General Tips...
    Last Post: 10/19/2006, 02:38 PM
  5. Headlight's out!
    By Lease-V-cross in forum VX Troubleshooting...
    Last Post: 11/26/2005, 10:22 AM
