I originally posted under rear door popper - but I think like someone said - everybody is pooped on poppers. My question is electrical though - I used directions that were posted to hook up the popper to work with my remote by hooking into the relay in the left kick panel. The remote now opens both doors on the first press, and the rear hatch on the second press. However, if I push the power lock button on the doors, the doors unlock AND the hatch opens - and if I press the remote hatch release button, it opens the hatch but blows the in-line fuse.
Of course the problem is that by hooking in the door lock system, I'm sending power both ways, allowing the hatch to open whenever the power door lock button is pressed, and the remote hatch switch probably doesn't have a high enough wattage fuse to operate all the locks - BUT I REALLY want the hatch to open remotely - anybody have any ideas how to solve this with a relay or some other means??
) But I'll describe to you what I did, and what I'm thinking of doing. If you have a wiring diagram for the VX, it should be easy to follow:
Anyway, I'll try again tomorrow, surely betwenn one of the three things I've come up with SOMETHING will work! If not, I'll just wire it into the shifter so it can't be popped at 60 mph, like Gary suggested. Thanks for the help OmegaVX! Sometimes just having someone interested that you can bounce ideas off helps you get through it!
