I'm looking for a 3 inch lift kit please help
Codyman checking out!!
I thought this thread was VERY interesting. Lots of things to think about!
The 913 Experiment by Rickshaw
Also check this out:
Lift Wiki
You'll find a lot more threads on this topic via the search engine, although the repetition of this question will make it hard to find the best threads.
You'll need a pair of OME 912 springs for the rear and a socket set to raise the front torsion bar ! Nice and easy (and cheap)
Hi, check out "rocky road outfitters" they do a complete ome kit for the vcross + some other useful bits, Iv'e bought 2 kits for other vehicles (jeeps) from them before and they have both been Brilliant!! offroad with Superb!! ride quality www.rocky-road.com
Calmini have a 3" kit available. Check them out at www.pureisuzu.com
2 x 99 JDM VX's 3.2L V6; 1 stock & 1 with 3" Calmini lift, 2 x Troopers, 1 stock & 1 with 3" lift ++
2 x Pickups and counting
Those "kits" contain a lot of unneeded extras...you simply need springs for the rear (your choice dependant on desired hight...OME 912, 913, or 919's). Crank the torsion bars up front, flip the ball joint if needed, get an alignment...done...tried, true and tested A search of the site will net you a ton of info on how to do this.
Totally agree. Try the search function at the top of the main page, you can find A LOT of info that way and if you don't find it there please feel free to ask :-) Here is my write up for my lift project. It is super easy, springs (I got 912's, 919's are just a slight taller and stiffer) and torsion bar crank, then get a lifetime alignment at firestone so you can mess with it later and never have to pay for an alignment again.
http://www.vehicross.info/forums/sho...light=Bigbeast
Last VX I had I did the Calmini lift. Whats the price for just doing springs and bumpstops alone and where to order. With the 919's how much lift are they?
I always take life with a grain of salt. Plus mashed potatoes and gravy!
