My TOD gauge shows the back wheels lit up while in tod mode, but the front wheels either dont light up at all or they sometimes will flicker full 50-50. I have driven in snow and ice to try and make the wheel slip to show the power to the front, but no luck. My TOD check light is flashing, so I pulled the codes per this link http://www.vehicross.info/forums/sho...ight=tod+codes I have a 14 and a 24 code ( front and rear speed sensor) last night I changed both rear speed sensors and kept the battery unpuged, but I am still getting the rear speed sensor code
I am a decent mechanic, but this is boggling my mind. I have put in a new TPS sensor, and replaced the actual TOD display gauge from the pod.
PS: When I put it into 4x4 low all of the lights come on solid.
