so basically for the diff drop it looks like I would cut out the bolt holes, slide the whole assembly down about two inches, and then weld it back in with some filler plate? What did you guys use for filler on the bracket? or I can get a second set of brackets from the junk yard and weld the bolt holes in from that to the plate?
