You can't spell "prick" without "Rick".
(I hate when people ask, "What's up, Rick?" Have I just been secretly insulted? It's impossible to tell.)
I know you'll love your PROTON. I love mine! With regard to your windows, like others, i needed the 'fix' on my driver's side and purchased an OEM regulator from IsuZu at about $70 if I remember correctly. I know they're still available since i just got mine recently. Also, 'street boutiques' sells a metal 'bottom-of-the-window' bracket kit that I got but didn't need afterall so I have it in my garage as a potential fix if I have any further problems with the windows. He sold that for $60 or $65 including shipping.
The VX emblem can replace the ugly 'isuzu' one in the grill which i think one of our members is making them again. I got the titanium one (I think that's what it is?) for mine. WELCOME TO YOU! scott
Regarding the window regulator... my passenger side gave out long ago and when I went to figure out why I took the regulator motor out for examination. You DO NOT need to replace the regulator assembly if the motor simply gives out! The binding causes the motor to burn up the brushes, that's all - from what I saw in my case anyway. When you widen the track, add lube, and do all the tricks to keep the window from binding simply pull the motor apart. You should see the copper windings in good shape but the brushes will have burned away. All I did was head to Ace Hardware and pick out a pair of motor brushes that looked like they would work in place of the burned out brushes from the regulator motor. The brushes came from a large drill or some other power tool. I used a round file to alter the shape to work in the motor assembly and PRESTO! a $10 fix!
HAHAHA! That's great!
BUWAHAHA! Yes, Daddy, sorry, Daddy.
Khoi, I hope you got your answers amongst all this goofin' 'round...?
thanks a million guys. I really appreciate all the help hopefully I will order the wheels and tires this week. VXKAT Hooked me up. I got the yakima racks from her shes the best!! and I ordered the Mega warrior Basket. The only thing is yakima says they dont make a spare tire holder/lock
Yakima is obviously confused....And it includes a locking mechanism.
http://www.yakima.com/shop/cargo/gea...e-tire-carrier
ebay - $66.99
http://cgi.ebay.com/Yakima-Spare-Tir...#ht_2164wt_725
here's the locking mount brackets I bought. Locks the basket to the cross members.
http://www.etrailer.com/Accessories-....html?feed=npn
Glad it's all coming together for you. Rack ships out Monday.
Glad to hear it! Here ya go:
http://www.4wheelparts.com/Bumpers-T...&t_pn=ORUD8655
http://www.man-a-fre.com/pa3/univers...etiremount.htm
Also check out what this guy did: http://www.skidmore.edu/~pdwyer/e/rack_attachment.htm
Riff raff of anyone? I just want to confirm My proton is stock height I got some 16x8 rockcrawlers and am thinking about purchasing some mickey thompson MTZ's. Riff raff mentioned I can fit a 285/70/16 on stock height. But the tire shop is saying i cant. I know alot of times these people dont know much especially about our vx's just want to make sure someone has done it already and it will fit on the stick height. Give me your thoughts. I looking for a real aggressive look. I know i can run a 265/75/16 but I would rather the wider tire if it will fit. thanks guys
Riff raff or anyone? I just want to confirm My proton is stock height I got some 16x8 rockcrawlers and am thinking about purchasing some mickey thompson MTZ's. Riff raff mentioned I can fit a 285/70/16 on stock height. But the tire shop is saying i cant. I know alot of times these people dont know much especially about our vx's just want to make sure someone has done it already and it will fit on the stick height. Give me your thoughts. I looking for a real aggressive look. I know i can run a 265/75/16 but I would rather the wider tire if it will fit. thanks guys
khoi,
We've seen enough variations from VX to VX significant enough that there won't be any guarantee that they'll fit.
On the bright side, if you get the MTs and you do get some rub at full lock, lifting the front about 1/2 inch is very easy to get the clearance you might need. It's just a matter of cranking the Torsion bars a few turns & then get a front end alignment (which you should get with the new tires anyway).
The alternative is some very slight trimming of the cladding. Again, very easily accomplished.
I say go for it.
I generally stick with stock as I do not 4 wheel. All these questions about tires dont the tire companies know what will work on vehicles? I know tirerack has a fitment program as well that will show what fits though I never used it for large sized tires.
Carter Pewterschmidt
Craig, to give you some idea......here's the minor trimming of the front cladding. I realize you're talking 16"s and mine are 18s.
I have 285/60-18s on OEM 18" rims, and NO TB cranked, and no lift, no special springs etc....and this is ALL I had to trim...and it's very easy.
Like Tom4Bren said, we've seen several instances where people encounter slight variances and tolerances, so you may have a slightly larger or smaller piece to cut, etc... vt. mav said he had to trim cladding to a slightly different degree on each side for his tire/wheel application, so he obviously had some variance, but all very doable.
I think Tire Rack's program only gives you a "Yes/No" as to whether something will fit. This site gives you all the numbers (how much less space at the top of the wheel well, whether the change in offset will affect the suspension and/or brake system, etc.) so that you can take a ruler out to your rig and see for yourself.
http://www.rimsntires.com/specs.jsp
I went to 265/60/18's on 8x18 Borbet rims with -2 offset (stock is +38) which caused the tires to stick out 2" further than stock. By contrast, going to a 285/60/18 on stock rims (as Sue and others have done) causes the tires to stick out only 0.8" further than stock. That difference is why I trimmed a tiny bit more but at a different angle.Originally Posted by VX KAT
I got those numbers from the link I posted above. When you fill out all the info you'll get this analysis back:
Package will stick out 50 mm (2'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset. Will fill out the wheelwell by extra 12 mm. Acceptable for most cars.
What's the backspacing/offset? What Riff was talking about with the 285/70/16 assumes that you're using the stock rim, which is actually only 7" wide. The extra width on your rims means your tire should stick out at least an additional 1/2" (correct my math here everyone if I'm wrong) - but it could be more if the offset is lower than +38 (stock offset).
The tire should fit with some minor trimming of the front cladding, but the shop probably doesn't want to do that, which is why they're telling you they won't fit. You may want to have them mount and balance the tires for you then take them home to install them so that you can do the trimming yourself.
