1996 Suzuki X90 with two problems:
1) Fuel pump is shaky. Mechanic says its working but troubled and may be cuasing me the hesitation I have in the morning, along with less fuel efficiency than I sholuld be getting. My confusion lies in the rather wide price range I get when I google for a replacement:
http://www.google.com/search?hl=en&q...og&sa=N&tab=wf
Anywhere from $43 from Rock Auto parts, up to $169. I am sure that there is some correlation with brand, with the available choices being in order from cheapest to most expensive:
Rock Auto's PEFP ($43)
OE ($85)
Denso ($85)
Bosch ($95)
Delphi ($151)
AirTex ($157)
Spectra ($163)
Carter ($169)
Some of these appear to come with just the pump, others have fittings and whatnot. So the quston: Which do you recommend?
2) I have a Service Engine Light on which resolves to a bad O2 sensor: bank 1, #1. I run into the same wide range when I google shop it, with the added confusion about not knowing which wire option I am supposed to get. Prices range from $30 to $166:
http://www.google.com/search?hl=en&t...&aqi=&aql=&oq=
Discount Body Parts 3 wire ($30)
JC Whitney SNG ($49)
Rock Auto Bosch 4 wire ($65)
Denso ($85)
and it goes up from there.
So same question, which one do I get?
