Quote Originally Posted by atilla_the_fun View Post
ISSUE SOLVED:
After removing the bumper I found bread in the area behind the flasher and then saw that a Squirrel had set up shop and had chewed through and completely severed the bundle of wires that contains the turn signal, the low note horn, the fog/driving light, leaving only the radiator cooling fan unscathed.
All fixed after a couple minutes of splicing..
A cupla years ago, a squirrel cause about $800 damage to the RV by chewing up wires (O2 sensor & coil wires).
You may want to keep an electronic pest repeller plugged in near where you park your VX. They carry them at Lowes in the lawn & garden section.
