Results 1 to 15 of 17
Thread: front flasher - turn signal not working, no power - rapid flashing of rear
    Feb 2010
    2001,Kaiser,1130
    ISSUE SOLVED:
    After removing the bumper I found bread in the area behind the flasher and then saw that a Squirrel had set up shop and had chewed through and completely severed the bundle of wires that contains the turn signal, the low note horn, the fog/driving light, leaving only the radiator cooling fan unscathed.
    All fixed after a couple minutes of splicing..
    '01 Ebony #0939
    You know, I had a feeling that's what the problem was all along, I just hadn't wanted to say it and make myself sound like some sort of know-it-all.
    Probably safe to say that wasn't in the troubleshooting flow-chart in the manual.
    Quote Originally Posted by atilla_the_fun View Post
    ISSUE SOLVED:
    A cupla years ago, a squirrel cause about $800 damage to the RV by chewing up wires (O2 sensor & coil wires).
    You may want to keep an electronic pest repeller plugged in near where you park your VX. They carry them at Lowes in the lawn & garden section.
    glad you got it taken care of
    Oct 2004
    2001, Yellow (PROTON) VX, Supercharged
    DARN VARMENTS!!!
  1. Replacing relay/flasher for LED turn signals
    By Bill Brown in forum VX Modifications...
    Last Post: 05/07/2020, 03:44 PM
  2. White Front Turn Signal Lenses Covers
    By piluf in forum VX Modifications...
    Last Post: 06/10/2011, 07:09 AM
  3. Suggestions for LED Turn Signal Rapid Flash?
    By vt_maverick in forum VX Troubleshooting...
    Last Post: 06/08/2011, 10:41 AM
  4. LED Front marker & Turn Signal Mod
    By Tookie in forum VX Modifications...
    Last Post: 09/26/2010, 04:29 PM
  5. Turn Signal Flasher Replacement
    By tysamigo in forum VX Modifications...
    Last Post: 05/27/2007, 10:47 AM
