 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						Have either of you (CP or Sue) tried to use this stuff on roof racks, spoilers, door handles, etc?
 Super VXer
						Super VXer
						From their site....
For the Black dye a 2 mineral spirits to 1 dye ratio is about right but check your manual for its own ratio needs.
The Grey dye is thicker and is approximately a 3:1 ratio. Watch the sprayer for spitting.
Just checked my notes (yes, I'm anal retentive) when I got home.... Used 2-1 ratio MS - Dye.
Used on Door Handles only as they are the same plastic as the cladding... I did not use on the roof rack, spoiler or hood insert as I was not sold that this would do the trick... Painting my hood insert and may paint my mirrors body color.... Not sure what I'm going to do with the rack & spoiler at this point
 Super VXer
						Super VXer
						I did door handles, very lightly and yes, it did act like it was cladding. I also skipped doing the mirrors, rails, spoiler or insert as I didn't think it would absorb the same, since it seems to be s shiny, smooth, denser "plastic".
Did you buy gray or just black? Are you mixing color? just curious.... and yes the gray is thicker, so the mfg told me to add the black TO the gray when I mixed it.
Ditto what the others have said. Terrycloth covered foam pads for first coat, waited about an hour to dry, followed by preval sprayer diluted 2:1 with mineral spirits. Used approx 1.5 bottles of all black. Door handles OK, pretty much anything else NOT OK as the stuff wont penetrate correctly.
As an aside, I did test the the half moon area with some Refinish Restorer afterward and advise against it. The solvents in RR will lift the dye and cause streaking, which was easily fixed with more Showroom New dye.
 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						Showroom new eliminates the need for any kind of armorall type product. It makes the plastic and not shiny. Good stuff. Mud has no effect on it. Still nice and black.
 Super VXer
						Super VXer
						Correct, I used SN on the half moon, came out beautiful, no streaks at all cuz it's a small area and you can apply it easily in continuous strokes. ....and just to muddy it up a bit..I left the R/R on my half moon and didn't blast it off with the pressure washer...and the SN went on and soaked in apparently just fine.
DId you start on it yesterday?
(Those white streaks at the top of the moon are just in the picture, think it was snow.
 Super VXer
						Super VXer
						Gotta believe that if you don't treat it with a detailing product at least occasionally you'll need to do this again eventually though. But since it sounds like application is about the same as 2-3 coats of B2B / Armor All / TS-1 maybe preventative maintenance isn't worth it.
 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						Does it have a UV protectant? Did the original cladding have a UV inhibitor? I'd think sun would be far more damaging over time than mud or water.
