OMG! I've got myself two little lizards!
OK, who are you and what have you done with VX KAT?
We caught these two outside on our walls, to keep my dog from eating them. I've been trying to ID them, but no luck.
Can some of you herp lovers help me figure out what they are?
So here's the adventures of Ziggy & Marley:
? Both are about 2" long + tail.
? I've had the larger one (Ziggy) for 10 weeks now, the other one (Marley) for about 3-4 weeks.
? The first one has grown a bit, even shed his skin this week. Can still see some old scales on his left rear leg. Cool!
? The smaller one has two bright parallel streaks of TEAL BLUE down the length of his stomach.
? Both are eating crickets very nicely! I dust the crickets with calcium 2x/week, plus put a drop in their water.
? Based on all the info I've read, I need to determine:
WHAT TYPE OF LIZARD so I know what temperature range they need.
? I've been basically assuming they fall in the "desert" category since our temps range from 20-30 low to 95 high. So they're surviving somehow in this colder weather. Our humidity is so low, I just didn't think they'd be considered "tropical".
? Just got my 2nd enclosure (larger) (this hobby is kind of addictive as well as FUN...I've been buying all kinds of stuff the last 2 weeks....lights, domes, stands, screen tops, digital temp gauge with remote sensor and a stick-on temp gauge)
? Also got the Reptisand as a substrate now instead of just rocks from outside. It has calcium in it too. Unfortunately, it seems to really stick and/or color them.....so the purple or orange cast on the lizards is from the sand.
? The bigger one now burrows into the sand for the night time.
? Both are basking on the big rock under the infared bulb.
? Got the lights all set up now too:
? UVB 10.0 CFL bulb (which also gives UVA)
? 50W infared
? 75W infared as the winter temps in my den here they'll need a little more heat.
? Been doing all kinds of temperature testing with the lights in different configurations:
? When both the UVB CFL and 75w infared are on, temp got up to 92 within 12 mins.
? With UVB and 50w infared, up to 88.5
? Both are much more active when I got the temp up around 84
? Both were hyperactive when temp was around 90 so I felt that was too hot, immediately switched to the 50w bulb.
? Now temps average around 84 - 88
