Originally posted by paultvx
I did pretty much the same thing with my V1. I tapped the ignition. Detector turns on and off with the key.
You mentioned in the "fuzzy hole" post that you put your V1 remote in the hole.  I was wondering if you had to drill a hole to run the wire to the remote?  I know that the fuzzy hole is removable...any need to drill it?  I am considering this setup myself!
*** P.S.---you mentioned about your ticket...it was laser right?  Did you get any indication from the laser detection?
Thanks in advance for any response.
