Results 1 to 15 of 93
Thread: Nuke VX build thread
    Sep 2009
    1999 White Vehicross 1385
    The list is extensive, yet simple.
    Work backwards from tire size.
    I did a bunch of calculations before I came to the realization that the tire size I wanted would not work with my axles.
    From there, choose axles that will fit reasonably close (Scout Dana 44 just a couple of inches off) or prepare for axle width customization.
    Don't forget to figure in where the differentials are in relation to the proposed transfer case (L/R/C front and rear).
    Get replacement engine measured to make sure it will fit between firewall and radiator, then between hood and proposed axle height. (This is the time to consider if you want A/C and where you can fit a battery too.)
    Get replacement transmission/transfer case measured to make sure it will fit to engine (with or without adapters) and the transmission tunnel.
    Fab up some engine mounts and modify transmission support.
    Suspension? Coil over springs are quite easy to fab and mount while accounting for shock placement.
    Get driveshaft lengths measured to find junkyard or order new ones.
    The rest was just customizations - upgrade to chrome-moly axles shafts, ARB Lockers, aftermarket gauges, A/C, Tom Woods off-set U-joints, Warn locking hubs, roll bars, front/rear receiver hitches, winch, etc.
    Very cool sir...hats off to you...
    Sep 2009
    Those rocker switches come with the purchase of the ARB lockers. One is for pump on, 2nd is for rear, 3rd is front (set to be activated in that order). They have a blue light to show when each is activated.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    Where did you get those switches from that are showing in the interior next to your steering wheel? I was thinking about doing something like that when I mod in a TOD-off switch.
    Here ya go: LINK
  1. Figured I should start a build thread
    By eternal21 in forum Build Projects
    Last Post: 05/25/2020, 04:34 PM
  2. RADO's Off Road Rig- Build Thread
    By VXorado in forum Build Projects
    Last Post: 11/18/2018, 01:27 PM
  3. AutoPros V8 Build - Photo Thread
    By AutoPros in forum Build Projects
    Last Post: 02/27/2015, 07:16 AM
  4. Off-roading the Nuke VX at Superlift ORV
    By sleveritt in forum VX Talk...
    Last Post: 03/22/2014, 11:28 AM
  5. VT_Maverick Build Thread
    Last Post: 01/22/2012, 07:19 AM
