Results 1 to 15 of 20
Thread: VX wiring sheet from DEI database
    Oct 2002
    '01, Dragon Mica Green NO MORE, 1393 SOLD
    If you are thinking of installing your own alarm, I got a hold of a wiring cheat sheet from DEI's database. It'll make your install easier. The PDF can be downloaded here.
    I also have a wiring diagram for those who wish to install their own power rear gate popper (source your own popper, soleniod, switch, etc.)
    The diagrame is here.
    Feb 2003
    2001, Black, VX, 0781
    You left the b out of web, the links should say:
    http://mywebpages.comcast.net/p_ting/VX/VXwire.pdf
    http://mywebpages.comcast.net/p_ting/VX/popper-wiring.JPG
    Oct 2002
    Fixed it... sorry.
    Thanks, any chances of getting a cheat sheet for 1999 models? I know for a fact that wire colors are different - at least in the ignition harness.
    Oct 2002
    Dunno... I can ask, but don't count on it.
    Any effort is appreciated! Thanks
    Oct 2002
    '99, Black #1439
    I have tha 99 dei info, but its printed out so ima need the: how to make a pdf for dummies book to get it up here any advice info, so i can share tha knowledge...x
    Oct 2002
    Scan it and save as PDF. Well, there's a little more to it than that. You'll need Full version of Adobe Acrobat or some sort of image editing software that allows you to save in PDF format. If you don't have it... send me a copy and I'll make it.
    Oct 2002
    '99, Black #1439
    Exclamation fax
    hows about a fax number to get it to ya ; ) i can do that with great ease ....x
    Oct 2002
    No fax available sorry. Got a scanner? If you can get access to a scanner, scan it at 100%, 150 dpi. Email the file to me as a JPEG, then I can turn it into a PDF.
    Oct 2002
    00/Ironman/0618
    Silver Box
    That�s a nice wiring sheet.
    Where can I get one for the silver box under the CD changer with the 96 wires going into it.
    The plan is to relocate it and use the space for the climate controls.
    I�m gutting the whole dash and fabricating a new center console.
    I need lots of space for a seven inch LCD display & DVD player.
    Everything MUST GO!
    As for the telepaths, I have learned to recognize them and
    ignore them. The worst thing you can do is block them and
    make them mad, When it gets to be too much, I put my
    fingers in my ears and sing, "FLINTSTONES, MEET THE
    FLINTSTONES."
    Aug 2003
    1999,Silver,Vehicross,0928
    did anyoneg get the wiring thing for the 99 vx? can you please post....or just answer my 1 question...wat is the orange wire for the radio do? and is there no ground wire for the 99 radio?
    ________
    CHEAP BONGS
    Dec 2003
    99 white Ironman 0922
    Here is what the factory service manual shows:
    radio connector pin numbers
    14-clock
    04-power
    11-illumination
    03-illumination dimmer
    No ground shown
    others are speakers
    Mar 2003
    Let's see how this translates... this is directly from Techsoft... DEI's database... I haven't looked at the one you already posted... but I'm sure its the same thing. Again... this is the 99 VX info from Techsoft...
    | ITEM | WIRE COLOR |POL| WIRE LOCATION |
    | 12V|white & white/black |+ |ignition harness |
    | STARTER|blk/wht or wht/blu |+ |ignition harness |
    | IGNITION|blk/yel or blk/red |+ |ignition harness |
    | SECOND IGNITION|blk/red or blk/yel |+ |ignition harness |
    | ACCESSORY|blue |+ |ignition harness |
    | POWER LOCK|red/white |- |drivers door harness or *1 |
    | POWER UNLOCK|red/black |- |drivers door harness or *1 |
    | LOCK MOTOR|lt. green | |drivers door harness |
    | UNLOCK MOTOR|lt. green/black | |drivers door harness |
    | DISARM DEFEAT|lt. green/black | |passengers door harness |
    | PARKING LIGHTS +|green/red | |drivers kick panel |
    | PARKING LIGHTS -|yellow or grn/yel | |headlight switch |
    | HEADLIGHTS|red or red/blu |- |headlight switch |
    | DOOR TRIGGER|red/green |- |passenger kick panel *2 |
    | DOME SUPERVISION|use door trigger | | |
    | FCTRY ALARM ARM| | | |
    |FCTRY ALRM DISARM|lt. green/red |- |drivers door lock switch |
    | DISARM NO UNLOCK| | | |
    | TACHOMETER|black/red | |PCM *3 |
    | SPEED SENSE|lt. green/white | |PCM *3 |
    | BRAKE WIRE|red |+ |brake switch |
    | HORN TRIGGER|green or orn/blk |- |steering column |
    | WIPERS|blu/yel & blu/wht |+ |wiper switch |
    | LF WINDOW UP/DN|blu/red - brn/wht |A |drivers window switch |
    | RF WINDOW UP/DN|blu/red - brn/wht |A |passenger window switch |
    | RADIO 12V|red/white |+ |radio |
    | RADIO GROUND|black |- |radio |
    | RADIO SWITCH|red/blue |+ |radio |
    | RADIO ILLUMINATE|green/red |+ |radio |
    | LF SPEAKER|blue - yellow | |radio or speaker |
    | RF SPEAKER|green - gray | |radio or speaker |
    | LR SPEAKER|red - white | |radio or speaker |
    | RR SPEAKER|blue - white | |radio or speaker |
    Notes:
    *1 Also found at the keyless module located to the drivers side of the steering column.
    *2 Located high in the passengers kick in a white 22-pin plug. *3 Found in a red plug of
    the PCM located in the center console.
    If it didn't work out... I can email the text file from wordpad. Enjoy!
    My Webshots Gallery...
    Aug 2003
    theres no black wire for teh ground for the radio...and theres an orange wire tat comes out of the antenna plug...other then tat everythign else is correct for the radio atleast
    ________
    Live Sex Webshows
  1. Aftermarket Fog Light Database
    By VXorado in forum VX Modifications...
    Last Post: 09/30/2013, 05:45 AM
  2. Right side O2 Sensor wiring/TOD wiring harness proper locations
    By CowboyErik in forum VX Troubleshooting...
    Last Post: 07/27/2013, 10:32 AM
  3. Database of Junkyards with VX, Rodeo
    Last Post: 05/24/2012, 11:15 PM
  4. Online Preview Tool with a VX in the database!
    By E-ZooZoo One in forum VX Talk...
    Last Post: 10/31/2006, 03:09 PM
  5. Need Wiring Help!!!!
    By SPAZZ in forum VX Modifications...
    Last Post: 12/05/2005, 12:43 PM
