Results 1 to 15 of 25
Thread: I want shiny black rims!!! 18 or 20"!!! HELP
    Oct 2007
    2000 Victory White Ironman
    I'm trying to find black chrome or a high gloss black rim for my VX but I don't understand the sizing, spacing, lug, etc. Is there anyone that has a suggestion for a rim that will fit that looks like this:
    http://image.made-in-china.com/4f1j0...-Wheel-Rim.jpg
    Just take your stock rims, or find another set of stock rims cheap, and powder coat them.
    Oct 2007
    Will powder coating be shiny black? I don't like the flat or matte black...
    Check on what is available in your area, but most good shops can do almost any color and in whatever finish you want.
    Check this out for what they look like
    Lugs 6x5.5 & 6x139.7 or most chevy,toyota, isuzu
    Offset stock is 18x7 +38mm, 0mm or -mm will cause the wheels to stick outside the wheel wells- check rim/wheel thread for different setups
    Jan 2011
    2001,proton yellow,0631
    hey mile high...you getting a commission from rich payne for promo-ing the rig he's got for sale?
    +1 - If you use your stock 18's you would end up looking pretty close to the picture you posted. I'm not too familiar with powder coating though - I've always known wheels with those finishes to actually be primed/painted/clearcoated.
    Quote Originally Posted by VXjunky View Post
    Gotta help out a Colorado brutha' when I can...
    2001, Dragon Green, 1342
    108mm center bore, some say the 100 will fit but there might be a interference problem with hot hub's if you need to get the wheel off. I have a +18mm offset with the 285/60 tire and it sticks out about 3/4 inch.
    I"m running an 18 x 8 1/2 wtih -6MM offset with 275/60 and sticks out about an inch.
    Oct 2007
    Thanks guys!
    Mar 2010
    2001 Ironman 0588
    Not 100% sure, but I think the process ends with a paint coat (any color) and clear powder coat baked over that. I had it done to the stock wheels on my Mustang for $100/wheel. I had them keep the bare metal around the outer edge (the transition is razor sharp) and they came out looking like they were made that way. It took about 5 or 6 hours from start to finish including them removing the wheels/tires, balance & re-installation. Google "wheel restoration" in your city.
    Aug 2008
    x2. I agree with the others-- that "powder-coating" your stock OEM 18x7 rims is absolutely the best way (and cheapest) way to go. The OEM rims have the correct offset/backspacing you will want to maintain to minimize rubbing of oversize tires. Just look in the "paper" yellow pages for a local powder-coating shop in your hometown and go talk to the Manager for various ideas and pricing on powder-coating. You'll be amazed at what a talented and creative powder-coater can do!!!
    As RickOKC mentioned, I'd just powder-coat only the center spoke area in high gloss Black (base-coat Black, with Clear top-coat) and leave the outer rim original chrome for a radical two-tone effect and also leave the OEM center-caps chrome as well. That would look totally bad@ss!!!
    Jun 2007
    2001, Proton
    Fyi
    Powder coating is extremely durable. Newspapers use them on the machines they put out on the street and beleive me those machines take a lot of abuse. It can be shiny and any color. My concern would be our OEM chrome rims peeling underneath as they have a tendency to do. I checked it out I had a price of about $125 a rim around
    Carter Pewterschmidt
  1. 16 " Inch rims
    By VX FIX in forum Miscellaneous Items For Sale
    Last Post: 01/30/2017, 07:45 PM
  2. Official "Black Hood Club"(BHC) Thread.
    Last Post: 06/25/2012, 10:40 PM
  3. After market rims 20"
    By sam in forum VX Modifications...
    Last Post: 10/31/2005, 03:32 PM
  4. Help, What black 16" rims will fit a 2000 VX
    By dkehn in forum VX Modifications...
    Last Post: 03/16/2005, 08:03 PM
  5. WOW..285's fit my 18" rims??
    Last Post: 01/07/2005, 08:01 AM
