Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: What's the most backspacing you've seen?
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    I know this can/will depend on the overall diameter and thickness of the tire/wheel combo. I'm looking at buying/mounting an 8.5 or 9" tire/wheel combo. I'm trying to determine how much of it I can shove back into the wheel wells.
    Specifically, the wheels I'm looking at have positive offsets in the 10mm to 30mm range. The larger 30mm offsets have 6" or more backspacing with the wheel width in question. Since it looks (to me) like the stock backspacing is 4.75-5", I'm trying to figure out where backside contact occurs.
    My tires will be between 30-31.5" in diameter.
    Thanks
    gp
    BTW,,,Yes, I'm a new owner!
    97 Jap Import, Black BEAST
    On the standard rims with no spacers you can mount a 285 75 16 tyre and it wont stick out beyond the wheel arches. you will need to attack the front cladding a little and the inner wheel arch for steering but the back has no issues.
    Go through the wheel and tyre thread, it has most combinations available and all the info on the different offset combo's
    This does look lifted though
    Or go the other way and just put all the tire outside the wheel arch
    I would try talking to marlin or littlebeast. Iirc they bothe have larger width rims with close to a factory offset, so that should at least be a little more backspacing than factory.
    01, LineX tan/black, 1055
    Yep, you got it. I got as close to factory offset as I could.
    Here is where I started, and since then, I have kept the same wheels as shown here, but went up to a 34"x11.5" tire. I also lowered the front end down to almost stock height, looks funny, but improved the offroad handling drastically. My VX just sits in the driveway most of the time, less than a tank a gas through it a month.
    Ultra Goliath wheels: 108mm bore
    6 on 5.5, 18x9, 5.5" back space, +12mm offset
    General Grabber AT2 275/65/18 P-metric
    OME919 springs
    14 turns on t-bar
    Feb 2010
    Thanked: 19
    Thanks guys.
    One thing that confuses me is the stock wheel is listed with 38mm offset. Since it's a 7" wheel, the center point would be 3.5". 38mm is right at 1.5".
    1.5" + 3.5" = 5" backspacking for the OEM wheel. (According to my calculations).
    But this chart shows it should be 5.5" backspacing. The chart looks wrong.
    Or I don't understand something.
    (I also did a search on backspacing. I looked thru most of the threads with that term. Not a single post mentioned OEM backspacing. Since my new VX no longer has stock wheels, I cannot verify what it SHOULD be.)
    If it's of any help, my Centerlines have 5" of backspacing on an 8" wide wheel.
    Thanks guys.
    JUST DO IT! Patience and thoughtfulness != timely mods.
    ***WINNER: Least helpful post in a mod thread Category***
    Feb 2010
    Thanked: 19
    Here's my real questions:
    1) Would a 20x9" dub with 10mm offset stick out 2" further than stock?
    2) Would the same wheel with 30mm offset have too much backspacing?
    10 and 30mm are the two choices for offset in a wheel I like
    Feb 2010
    Thanked: 19
    Ughhh....what's this forum category for? Since it included a GIANT wheel thread, I thought it was the correct location. Is it not?
    1) That's what I get (well 2.1" and change)
    2) If I understand the equations correctly, I think that 30mm offset would generate too much backspacing.
    Have you ever tried this? Punch in the OEM specs and what you're considering and see if helps you visualize all these numbers.
    http://www.rimsntires.com/rt_specs.jsp
    ***WINNER: Least helpful post in a thread Category***
    2829th post in a row.......
    Feb 2010
    Thanked: 19
    Wanna let me in on the joke?
    Apr 2010
    says that VT_Mav provides useless posts, nothing directed at you. We all love VT!
  1. OEM Rims offset and backspacing
    By joshi in forum VX Modifications...
    Last Post: 11/12/2010, 09:27 AM
  2. wheel advice offset/backspacing
    By djvx in forum VX Talk...
    Last Post: 06/12/2010, 08:04 AM
  3. Replies: 2
    Last Post: 04/17/2008, 07:12 AM
  4. 15" wheel backspacing?????
    Last Post: 03/03/2005, 11:18 AM
